Modelling Cavitation
Old   December 28, 2017, 05:38
Default Modelling Cavitation
Pina
dxue is on a distinguished road
When modelling cavitation on a hydrofoil, what are the values of inlet and outlet pressure one should enter to obtain a specific cavitation number?
dxue is offline   Reply With Quote
Old   December 28, 2017, 09:20
DEd
Daniel Edebro
DEd is on a distinguished road
The cavitation number is a measure of how close you are to cavitation and it can be defined for every point according to the following formula:
Ca = (p_loc - p_vap)/(0.5*rho*U_inf^2)
Where U_inf is the velocity far from the hydrofoil.
What do you mean by "optain a specific cavitation number"?
DEd is offline   Reply With Quote
Old   December 28, 2017, 09:47
Pina
What i meant to say is that I wanted to carry out the simulation using different cavitation numbers. This can be done by changing the magnitude of velocity.
I initially thought I had a wrong set up however the simulation was not converging due to incorrect initialization.
Old   December 28, 2017, 10:57
DEd
Daniel Edebro
Ok, maybe this is arguing about semantics but I wouldn't say that you are "using different cavitation numbers". The cavitation number is a part of your solution the same way that pressure is. Or in other words, the cavitation number is always an output never an input to a calculation.
On a side note: If you are doing valve analysis there is a global parameter called cavitation index (sigma) that is defined as:
Sigma = (P_up - P_vap) / (P_up - P_down)
This parameter can be used as an input value for a CFD calculation.
Old   December 28, 2017, 13:59
Pina
I am analysing the cavitational effects on hydrofoils and examining its effect on the lift coefficient.
Cavitation modelling Memboro CFX 6 November 26, 2015 05:56
cavitation modelling GJM1991 OpenFOAM Running, Solving & CFD 0 April 29, 2015 04:06
Modelling Cavitation in Pumps BigPapi34 OpenFOAM Running, Solving & CFD 0 August 29, 2012 10:29
Cavitation Modelling Options Torque_Converter CFX 2 August 12, 2012 12:08
Cavitation modelling !!! ROOZBEH Fidelity CFD 5 May 21, 2004 01:39
