Updating Fluent after meshing from Worbench Scripting, asks to update mesh again.
Old   January 8, 2018, 14:18
Default Updating Fluent after meshing from Worbench Scripting, asks to update mesh again.
UchihaMadara is on a distinguished road
I am trying to run an automated process where I import a cad to Geometry template, mesh it with mesh template and then attach this to fluent to direcly obtain the graphs and monitors section of fluent. i.e see it run.
So far I've written a JS script for meshing which is called from WB and it works fine uptill here. i.e import cad and mesh it. (green ticks for both)
But when I attach a 3rd template of fluent to the same script, mesh is asked to be updated again and fluent doesn't proceed to TUI commands built for it.
I assume if meshing is already done, then attaching fluent to this mesh must not require another mesh update. But it is asked and would like to know a work around or if there are none, how could I update the mesh again with script?
Do I use a Project.Update() after fluent is added or something else?
Could someone guide me if they know anything?
UchihaMadara is offline   Reply With Quote
ansys scripting, mesh scripting, meshing, scripting, workbench scripting
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 05:09
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting arunraj FLUENT 0 June 2, 2016 22:58
[ICEM] Missing face error from FLUENT even after repairing mesh + other questions unknown159 ANSYS Meshing & Geometry 0 July 5, 2013 20:18
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 11:21
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
