January 1, 2018, 10:26 |
Fluent - writing settings into file
Marcin
Rep Power: 9 |
After creating every necessary setting in Fluent (material properties, boundary conditions, solver settings etc.), I would like to export these settings into text file and then import it into other Fluent case, in order to avoid spending time on it twice. I know that this is posible using GUI. Please give me some advices. Regards Destroy |
January 2, 2018, 18:40 |
Lucky
Rep Power: 65 |
I don't think it's possible using button clicks in the GUI. In the TUI (which is available in the GUI mode anyway) you just type:
file/write-settings "filenameblahblah" Code:
file/read-settings "filenameblahblah" |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
