Simulation of Heat Transfer in Tubes in Fluent Software
hi,
a steel tube is used to transfer cold materials. The internal diameter of the pipe is 36 mm and the thickness It is 2 mm. Medium temperature and ambient air are 6 degrees Celsius and 23 degrees Celsius, and coefficients The corresponding displacement is 400 W / m2k and 6 W / m2k respectively. A) What is the rate of heat transfer to the drug per unit length of the tube? B) If the insulation of calcium silicate is of thickness of 04 mm and with conductivity coefficient of 0.5 W / mk on the pipe What is the rate of heat transfer per unit pipe? |
