Fluent simulation crashing everytime after 24 hrs |
January 24, 2024, 12:53 |
san
Rep Power: 3 |
I'm running some transient simulations in fluent version 18.2 on a standalone PC with parallell processing. My simulation is crashing exactly after 5100 timesteps. I am autosaving dat files after every 400 timestep. Hence, I'm able to rerun the case with the last saved file. But it again runs for next 5100 time-steps and crashes. The simulation is converging and this issue has nothing to do with flow dynamics as such.
The error in transcript file/gui is Abnormal exit when running with Workbench. If running through fluent alone, then the error message is "the fl process could not be started". I'm sure it is not a RAM issue as RAM usage is always below 25%. I'm guessing it is some sort of a system issue as it is happening after a fixed interval, but unable to find the source. I've tried rebooting system, reducing the number of cores, etc but it didn't work. I would be grateful if somebody can point me in right direction.. |
January 25, 2024, 06:41 |
Moritz Kuhn
Rep Power: 17 |
Maby a network error? Connection to the licence server lost?
January 25, 2024, 09:26 |
san
Rep Power: 3 |
I work on a standalone PC with internet connection off. Hence, doesn't think it's a network issue
crash, fluent - parallel |
how to run fluent from matlab without using aas toolbox? | artemis96 | ANSYS | 7 | May 23, 2022 12:16 |
FLUENT simulation only uses 20% of the CPU speed | ALBATTROSS | Hardware | 6 | March 8, 2019 20:20 |
Start new Ansys Fluent Simulation automatically | Malue | Fluent UDF and Scheme Programming | 1 | October 4, 2017 01:48 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Simulation on fluent 14 | NAD | FLUENT | 0 | September 11, 2013 02:05 |
