Can not access to the user variable of particle (DPM)
Hello.
I am working with DPM, and some scalar values would be updated along the particle track. That is, "DEFINE_DPM_SCALAR_UPDATE" will be used. After facing some trouble, now I am trying to test this simple code below. DEFINE_DPM_SCALAR_UPDATE(name_test, c, t, initialize, tp) { if (initialize) { p->user[0]=0; } } This is all of my udf; just initializing the user variable as zero. In Results > Graphics > Particle Tracks, I can draw the particle track colored by "Particle Residence Time" like so far. However, when I try to draw the particle track colored by "User Value 0", then it shows an error; Error: CAR: invalid argument [1]: wrong type [not a pair] Error Object: () I tried using P_USER_REAL(tp, 0), TP_USER_REAL(tp, 0), PP_USER_REAL(tp,0), instead of p->user[0], but they gave the same error. I did not forget to specify the number of dpm scalar in DPM panel in Fluent. I am using ANSYS Fluent r18.0 I am not sure but I guess this was not a problem when I used version r16.x, but I cannot test it now. How can I solve this problem? Thank you in advance. |
I could test the udf with ANSYS Fluent r17.2
It works well and I can draw particle track colored by "User Value" With the same *.cas file and udf code, why does it cause a problem in r18.0? Any idea?? Thank you. |
