ANSYS FLUENT excessive temperature change
Old   January 16, 2018, 14:49
Default ANSYS FLUENT excessive temperature change
tiago
tiagom is on a distinguished road
hi to you all.
i need help with a problem. as can be seen from the picture attached i keep getting the same error. so far attempted to:
- change the mesh to reduce skewness (so far its at 0.33)
- reduce the courant number.
- increasing the tempreture at which the computation is performed
nothing seems to work,
the problem i am trying to solve is a 2d simulation of a turbine tip blade flow, pressure inlet of 1 atmosphere and pressure outlet of 0.8 atmosphere's.
computation was first performed using explicit 1st order and then changed to implicit 2nd order where the problem occured.
any help i could get with this would be greatly appreciated.
tiagom is offline   Reply With Quote
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting arunraj FLUENT 0 June 2, 2016 22:58
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
plotting temperature time graph using ansys workbench fluent Hithesh FLUENT 0 March 30, 2014 12:30
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
FLUENT to ANSYS Temperature Mapping swkang Fluent UDF and Scheme Programming 0 April 3, 2010 19:02
