I need some advice with my boundary conditions (picture attached) |
January 18, 2018, 04:56 |
Mr CFD
Rep Power: 14 |
I have a system with three inlets and one outlet.
I am usually a CFX user. In CFX I would model inlet 1, 2 and 3 as an opening boundary condition:
January 18, 2018, 13:38 |
Lucky
Rep Power: 65 |
You need to supply the inlet pressures of the 3 inlets. Otherwise the problem has many solutions.
For the filter. Do you mean that you know the loss curve? For a given filter (i.e. a given loss curve), if you know the pressure drop then that implies you already know the flowrate across the filter. You shouldn't need to use the porous media as a cell zone model. Several BC's and interface options are available, i.e the porous interface, or even the fan BC allows you to input a loss coefficient or pressure jump. Or you could just give inlet 2 a lower inlet pressure. |
January 19, 2018, 05:03 |
#3 | ||
Mr CFD
Rep Power: 14 |
Thanks for your response LuckyTran.
Just to be clear - there is a suction pump at outlet 1 sucking at 10 L/min. Air is drawn through the inlets from atmosphere. Quote:
Since the operating pressure is atmospheric, I set the inlet pressure to 0 Pa. Quote:
January 23, 2018, 09:04 |
Mr CFD
Rep Power: 14 |
Hi, could anyone offer any further thoughts on this?
Thanks |
January 26, 2018, 16:24 |
Daniel Edebro
Rep Power: 10 |
One thought (except use total pressure inlet) is that you model a part of the space outside the inlet of the pipes in order to get correct contraction of the flow.
January 29, 2018, 05:15 |
Mr CFD
Rep Power: 14 |
Thanks DEd. I'll try that and see if I get better results.
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 17:19 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
