calculation of the heat transfer coefficient
Old   February 2, 2018, 20:28
Default calculation of the heat transfer coefficient
Marcin
destroy is on a distinguished road
I have a simple geometry and case - transient turbulent flow through a pipe. I set the case as axisymmetric.
The pipe is cooled by the air flow. Initial pipe temperature: 373 K, inlet temperature 303 K. Outside the pipe I set HTC=100 W/m2K and 303 K.
I want to calculate the distribution of the HTC in space and in time. For this I divided the length by 20, and on the every of 20 section I want to calculate some average HTC. Which Fluent option for this should I choose?
Regards
destroy is offline   Reply With Quote
Old   February 2, 2018, 20:32
Haidar Fakhri's Avatar
Suraji
Haidar Fakhri is on a distinguished road
Hi destroy
I try to help u
Please, you make a line sample in the inner pipe, as long as the wall. Ur case is transient, so u should make a graphic to observe every time step u set.
Thanks
Haidar Fakhri is offline   Reply With Quote
Old   February 3, 2018, 07:47
Marcin
I dont understand what do you mean and how your advice will help me.
The main question is - what option should I choose? Reports->surface integrals-> ...??
There are many options for calculating the HTC and I dont know which is valid for my case.
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 17:29
Heat transfer coefficient calculation h FastFlow CFX 3 September 28, 2016 16:56
calculation of value of convective heat transfer coefficient for a bank of cylinders sidrameshrath CFX 1 May 31, 2014 00:42
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 16:35
Calculation of Heat Transfer coefficient sachin CFX 2 February 16, 2009 03:24
