Analysing CD nozzle for the effect of swirling flow on the shock structure.
Old   February 7, 2018, 03:06
Exclamation Analysing CD nozzle for the effect of swirling flow on the shock structure.
Qusai
qusaimn is on a distinguished road
I am performing a CFD study to analyze the effect of different swirl numbers on the shock structure in a CD nozzle.I have been trying to simulate the shock for very long time.I have obtained satisfactory results for over-expanded flow in the nozzles with and without the swirl, however when i try to simulate the shock the solution never converges(flat line with oscillating residuals). I have tried a lot of stuff from changing the turbulence model to changing the under relaxation factors but to no avail.My mesh quality(created using ICEM) is pretty good and has close to a million nodes.I am certain the mesh is not a problem.My BCs are ,inlet pres=1atm and outlet pressure is 65kPa.I have attached the convergence map(outlet pressure at 45kPa).Any guidance will be of great help.Thank you in advance!
qusaimn is offline   Reply With Quote
Do you think axis symmetric will change the secondary flow structure? fruitkiwi Main CFD Forum 0 November 4, 2012 07:21
Con-Div Nozzle Shock structure problem padmanathan FLUENT 2 November 16, 2010 04:37
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Instability and Vortex/roll structure Z. Zeng Main CFD Forum 3 May 10, 2000 06:18
Flow Visualization of impinging swirling flow on the wall. sangaria Main CFD Forum 2 March 26, 1999 14:31
