Save output of udf in another udf!
Old   February 8, 2018, 12:43
Post Save output of udf in another udf!
JuanJoMex is on a distinguished road
I have a compiled udf fluent, this udf read some parameters and then you can define a energy and mass source with the udf profile. I will like to define different sources with different parameters with the same udf. There is a way for saving the output of the udf in another udf or save the profile of the source?
p.d. I canīt modify the primarily udf, i donīt have the source file.
Thanks in advance!
JuanJoMex is offline   Reply With Quote
profile, sources, udf
Need help in writing UDF for an oscillating airfoil to get Output parameters ned.musab FLUENT 0 October 27, 2017 11:21
UDF for output temperature mariam.sara Fluent UDF and Scheme Programming 9 August 19, 2017 08:22
udf problem.. output data comes out to "zero" startup0820 Fluent UDF and Scheme Programming 3 August 15, 2012 23:09
save data output at specific point using probe foam_noob OpenFOAM 0 March 11, 2010 02:13
How to save macro results in the output file? Peggy FLUENT 0 May 21, 2007 03:36
