February 12, 2018, 04:31 |
Coal Gasification
lalan kumar singh
Rep Power: 8 |
Hi everyone,
I am doing 2-D simulation of coal gasification. reversed flow in 18 faces on pressure-outlet 7. # Divergence detected in AMG solver: x-momentum -> Increasing relaxation sweeps! # You may try the enhanced divergence recovery with (rpsetvar 'amg/protective-enhanced? #t) I am getting this error at the start of iteration. Please do share if anyone know how to fix this error. Thank you. |
February 15, 2018, 02:35 |
lalan kumar singh
Rep Power: 8 |
Yeah, i have fixed the problem.
Thank You. |
March 9, 2018, 08:40 |
Model Used
luis Reyes Alonzo
Rep Power: 8 |
Dear kumar
Which approach, did you use? Euler-Euler or Euler-Lagrange.
Luis Reyes PhD student Insa Rouen France |
March 15, 2018, 03:43 |
lalan kumar singh
Rep Power: 8 |
Hi Dear,
I am using euler- lagrangian method for gas solid phase interaction. Thanks. |
March 15, 2018, 05:04 |
udf
luis Reyes Alonzo
Rep Power: 8 |
Dear Kumar,
Thanks for replying, i am working in cfd simulation of biomass gasification. i've heard it is necessary to use a udf fonction for ractions rates. For the reactions rate did you have to use a udf fonction? I would be very glad to ask you some questions about. Can i have your email ? My email is: luisreyesalonzo@gmail.com
March 21, 2018, 00:18 |
lalan kumar singh
Rep Power: 8 |
Hi Dear,
i am working on CFD modelling of coal slurry gasification. And in my case, there no udf used for reactions. Thanks. |
March 21, 2018, 11:03 |
#7 | |
19snr
Rep Power: 8 |
how you solve the problem, because i get the same problem like you please help Thanks in advance.. |
March 22, 2018, 03:26 |
lalan kumar singh
Rep Power: 8 |
Hi there,
You are doing 2-D or 3-D simulation? |
coal gasification using FLUENT-DPM | arnab | FLUENT | 23 | February 21, 2018 12:52 |
coal gasification detail mechanism in chemkin | akia | OpenFOAM Running, Solving & CFD | 0 | July 11, 2015 07:41 |
Nonpremixed Combustion Model for Coal Gasification | C.Y.Ler | FLUENT | 2 | April 29, 2014 08:51 |
Fixed Bed Coal gasification | nabeelicet | FLUENT | 0 | February 2, 2014 06:36 |
how to define the velocity of coal when using DPM in modeling coal gasification? | harry king | FLUENT | 1 | May 6, 2012 22:11 |
