"fl_mpi1820.exe has stopped working" error. Can anyone explain this?
Like Tree1Likes
  • 1 Post By LuckyTran
Old   February 16, 2018, 04:46
Default "fl_mpi1820.exe has stopped working" error. Can anyone explain this?
Billy
Billy_ is on a distinguished road
I am trying to complete a DPM simulation on Fluent. I have been recently getting this error which closes fluent whilst in the middle of the simulation.
I have only noticed this error once the 'DEM collision' feature is used within the DPM model. It usually happens when the simulation reaches the 9th iteration.
Alternatively, I have also gotten "cx1820.exe has stopped working" under the same circumstances as named above. I have attached an image of the error.
Could this be a hardware problem, not enough computing power?
Or possibly a windows error, im running windows 10 at the moment.
Is there a way to fix this, as I currently cannot run DPM simulations with DEM collision enabled due to this error.
Thanks in advance.
Billy_ is offline   Reply With Quote
Old   February 16, 2018, 11:40
Lucky
These are pretty generic errors that don't really say much other than Fluent has crashed. cx is the cortex process. mpi is the parallel process. Neither of these are DPM specific. Try running in serial mode, it might help you debug what's wrong with your case.
Billy_ likes this.
LuckyTran is online now   Reply With Quote
Old   February 16, 2018, 18:34
Billy
Thanks mate, will give that a try
Old   March 7, 2018, 16:32
Reza_pal is on a distinguished road
I am facing this issue also. Have you figured out what is wrong?
I am using Ansys 18.2 Fluent . I have a UDF to set the inlet boundary condition. When I use the UDF it interpret that and when I want to assign BC it shows the exact same error as you got.
I will get the error in both Serial and Parallel modes because my UDF is written in Parallel format and the code automatically changes the serial to parallel.
Any hint is appreciated.
Thanks
Reza_pal is offline   Reply With Quote
Old   March 12, 2018, 10:12
Hi, I fixed mu issue with this error. I was trying to interpret a UDF and it was interpreting without problem. But actually it had an error when it wanted to be executed. Also, When I opend the fluent from the Ansys, I couldn't run my UDF, Fluent had to be opened separately outside the ANSYS.
[OpenFOAM.com] [Windows] Error message "of_create_container.exe has stopped working" JohnMartinGodo OpenFOAM Installation 6 August 9, 2017 07:26
"ANSMeshingServer.exe stopped working" Error in ANSYS v13 Flougiman ANSYS 1 May 23, 2017 14:59
got error: "AnsysWB models has stopped working" oat FLUENT 2 September 17, 2016 03:18
no error but solve stopped to move on wjy-c CFX 9 July 16, 2013 23:12
continuation of stopped program Niru Main CFD Forum 0 June 19, 2013 11:53
