February 19, 2018, 04:38 |
Mesh and Simulation Convergence
Hells Blade
Rep Power: 8 |
For the same mesh and geometry at a lower pressure my simulation runs and for a higher pressure I get floating point exception
Divergence detected in AMG solver: temperature turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2136 cells reversed flow in 44 faces on pressure-outlet 7. Divergence detected in AMG solver: temperature Divergence detected in AMG solver: temperature Divergence detected in AMG solver: temperature Error at host: floating point exception Error at Node 0: floating point exception Error at Node 1: floating point exception Error at Node 2: floating point exception Error at Node 3: floating point exception Why do I get such an error at higher pressure(4bar) with the exact same mesh whereas it runs with a lower pressure (2 bar) |
February 19, 2018, 05:09 |
Rahul
Rep Power: 10 |
It means that solver is not able to capture the turbulence occurring in the flow due to high pressure for your coarse mesh.
You should refine the mesh. |
February 19, 2018, 16:05 |
Lucky
Rep Power: 65 |
Probably it is due to a poor initial guess or inconsistent boundary conditions. Check your case setup and try to give it a really good initial guess. I.e. when you changed the pressure, did you change the initial temperature (&density?), k, epsilon and so on also?
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
Fatal overflow error, singularity, due to local mesh form? | Thomasbr | CFX | 7 | July 8, 2016 09:57 |
[Other] Quality Mesh Analysis > relation with convergence | vitorspadetoventurin | OpenFOAM Meshing & Mesh Conversion | 1 | November 29, 2014 03:54 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 10:55 |
