February 20, 2018, 09:32 |
Splitting a model using outlet data
Max
Hi!
I'm trying to simulate a system that could be simplified to something like this: The a) part is a quite big tank that could be considered as stationary given the small mass flow through the pipe. The b) part, however, is essentially time dependent, as the tank will get filled over time. The accuracy of the fluid passing through a)'s outlet section (distribution of speed, temperature, etc.) is critical to the problem. I was wondering if there is a way of recording a)'s stationary outlet results and then use that data as an input for b), decoupling both problems and letting me simulate both cases independently. Thank you very much. |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Run OpenFoam in 2 nodes of a cluster | WhiteW | OpenFOAM Running, Solving & CFD | 16 | December 20, 2016 00:51 |
UDF for transient pressure outlet boundary from data array | nathanblank | FLUENT | 1 | June 1, 2015 03:09 |
How to: take calculated data from one model outlet boundary and use it at other inlet | EdgarasM | FLUENT | 1 | October 2, 2014 10:14 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
