[Sponsors] | |||||
Rep Power: 10 ![]() |
I am stuck on the last hurdle of my final year project and was directed here.
Basically my project requires me to find the coefficient of drag over a projectile and compare it to coefficient of drag versus the same projectile but with a base bleed system. I have a finished model for the standard projectile but need to get the base bleed projectile working. What should happen is by releasing a higher pressure gas into the wake of the projectile the coefficient of drag should go down. \I have done this by creating a mass flow inlet at the base of my projectile which does successfully reduce the coefficient of drag however when i look into the post-processing the pressure at the base is the same as the standard projectile. This makes no sense in theory. Can anyone think of what i might be doing wrong that the pressure created by the mass flow inlet is always 70000 Pa? I can upload files if required. Thanks. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 06:07 |
| Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
| Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
| Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
| Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 13:50 |
