March 12, 2018, 10:08
Drag coefficient computation problem
Hi everybody,
I try to compute the drag coefficient of a 3d model with ansys 18.1, i did the following steps: - Load the 3D model in geometry
Prepare->Enclosure to build the fluid domain
mesh
Now when i go to add as value to compute the drag coefficient i can't select the surface of the body becouse it's define as interface and not wall..
I saw some youtube tutorials but they are with old version of ansys and i can't find the command boolean to remove the model's volume and the remove material buttom in facets is grey even if i select more than one solid.
I would be grateful if someone could give me a hand
