How to set up from the empty condition?
Old   March 27, 2018, 09:26
Default How to set up from the empty condition?
chenkangpang
chenkangpang is on a distinguished road
In the beginning, the simulation is filled with pipes. How to set up from the empty condition? The mixture model is used in the oil and water two phases flow and only oil can be set up to 0 in the initialization.
chenkangpang is offline   Reply With Quote
Old   March 27, 2018, 15:10
Lucky
You only need to specify n-1 mixture fractures because the last one is always 1 minus the rest. I.e. a mixture fraction of 0 for oil necessarily implies a mixture fraction of 1-0=1 for water.
How to set the requirements for a boundray condition qjh888 OpenFOAM Running, Solving & CFD 3 May 10, 2016 20:06
how to set complex boundary condition, namely a developed velocity in inlet of pipe? milad653279 OpenFOAM Pre-Processing 3 January 4, 2016 09:46
How to Set Pressure Outlet Boundary Condition freeday Fluent UDF and Scheme Programming 1 August 30, 2012 11:49
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 08:28
What is empty boundary condition? lakeat OpenFOAM Running, Solving & CFD 6 May 7, 2009 05:16
