Need help - Divergence in AMG solver - temperature
Hi all,,
I am doing dual stream heat transfer analysis of 3 heat exchangers which are put together under a single domain. After modelling all the three heat exchangers under a single domain ( cuboid ), I mesh it. There are many contact regions created ( nearly 300 ). After that I mesh it. And I open it in fluent. I turn on the energy equation and I gave the cell zone. In boundary condition, I gave the air in(velocity inlet) and air out(pressure outlet) for the domain. Now for coolant I'm not able t give the boundary condition since all are under interface so that mesh interface is created. If I change the interface option to mass flow inlet, the solution is diverged and following error pops out. " Divergence detected in AMG Solver - temperature" "Temperature limited to 1.000000 in 22500 cells in domain 17" "Floating point exception" An if I delete all the contact regions, then also it is not working and the same errors pops out. What should I do now ??? I have clean mesh and geometry. Help me. Thanks in advance... |
reduce the Under relaxation factor for energy near 0.2 or reduce mesh skewness
But the thing is that I tried this method by reducing the UDF energy to 0.6 Still it showed the same error. Now my question is how to create a contact region for mesh interface ? Help me |
in mesh with the help of new contact region, we can create contact or in solver with the help of mesh interface by selecting srg and their respective trg
If possible, send me tutorial if you have any. Thanks. |
watch this video https://www.youtube.com/watch?v=NPJImYibx48
