Lift coefficient and drag coefficient when using symmetry |
April 13, 2018, 12:17 |
Lauren
Rep Power: 8 |
If I make a 3D wing using symmetry (so only half of the wing is tested) using ANSYS Fluent, does this mean I should double the lift coefficient and drag coefficient if I need results for the entire wing? Thanks! |
May 4, 2018, 15:30 |
I was wondering if you figured out the answer to this? Nowhere that I've found says it explicitly and I want to be sure! Thanks! |
coefficient, drag, lift, symmetry, wing |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
Drag and Lift coefficient for diffusor | rego | STAR-CCM+ | 3 | May 7, 2012 18:05 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
drag and lift coefficient | Noé | Siemens | 5 | July 13, 2004 10:21 |
