how to give normal velocity at area inside domain in fluent?
Old   April 18, 2018, 13:59
Default how to give normal velocity at area inside domain in fluent?
naman doshi
namandoshi is on a distinguished road
i have an area (0.25m^2) inside the room (3*3*3m) i want to give a normal velocity of 5m/s how to give?
i don't know the pressure jump.
namandoshi is offline   Reply With Quote
Old   April 18, 2018, 22:48
Sajan
sthapa is on a distinguished road
I am new in ANSYS too.. As far I know if u use mass flow rate inlet then there is a option to make it normal to the boundary...
hope this works for u
sthapa is offline   Reply With Quote
Old   April 18, 2018, 23:24
naman doshi
under which boundary condition?
wall
interior
porous ...
fan
only this are available
and how?
Old   April 19, 2018, 10:10
Kushal Puri
Kushal Puri is on a distinguished road
wall
interior
porous ...
fan
and how?
It will be little tricky you cant apple directly the velocity inlet on the face which is inside the fluid zone. You can follow the following steps.
1. Define -> Boundary Condition. Select interior-5 under Zone and select wall on the right column under Type. Click on Yes to change the type. Two internal walls will be created, wall-5 and wall-5-shadow. ID of wall-5 will be the same as the ID of interior-5. These two new walls will be coupled by default and the available types for them are fan, interior, porous-jump, radiator, and wall.
2. A velocity-inlet type for an internal wall does not exist. In order to have types that can be applied on external zones, they need to be split. How to split wall-5 from wall-5-shadow? In the text user interface (TUI), type: /grid/modify-zones/slit-face-zone wall-5. Two additional walls will be created: wall-5, and another wall-###. A message will print on the cortex window which displays which zone is wall-###. These are now two external zones, one is adjacent to fluid-1 and the other is facing fluid-2. To have the fluid entering the pipe, the one which is adjacent to fluid-1 needs to be changed to velocity-inlet type. To find which one is adjacent to fluid-1, you need to visit the boundary condition panel for that zone and look under 'Adjacent Cell Zone'.
3. Repeat the above procedure to apply pressure-outlet to interior-6.
Kushal Puri is offline   Reply With Quote
Old   May 23, 2018, 16:31
ahmed425 is on a distinguished road
I followed your steps to change an internal face to a velocity inlet. But is it possible that I can get the shear stress along that face ? I don't think I can since it changed to a velocity inlet but I was wondering if there is any way around that
thank you
ahmed425 is offline   Reply With Quote
How dose FLUENT define face normal? C_Zhang Fluent UDF and Scheme Programming 2 September 1, 2017 05:48
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 11:38
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
