Turbulent flow over a circular cylinder?
Like Tree1Likes
  • 1 Post By ck3
Old   April 27, 2018, 14:40
Default Turbulent flow over a circular cylinder?
ck3
Khaled
ck3 is on a distinguished road
I want to investigate a fluid flow over a circular cylinder for Re=3900. I use k-ebsilon Realizable turbulent model and steady solver.
I construct geometry for circular domain (with at least 60xdiameter of smaller circle).
y+=1, so I use Enhanced wall treatment.
for boundary conditions (see attached pictures).
Could you please help me to model this case? (How to seting boundary conditions to run this simulation)
Skp123 likes this.
ck3 is offline   Reply With Quote
Old   May 2, 2018, 16:41
ck3
Khaled
Any help please.
Old   May 4, 2018, 03:43
Leonardo
Leonardo.flores is on a distinguished road
It's not very common to see that circular pressure outlet bc. It's much common whith a wall up and down and a pressure outlet perpendicular to the streamwise velocity.... Check this paper https://www.researchgate.net/publica...and_Validation
That way you could move the pressure outlet further or closer, depending on your interest on the wake analysis.
On the inlet condition I use a turbulent intensity of 0.5% since I compare results with a wind tunnel with that specifications... 1% is ok. And length scale I consider 0.038*cylinder diameter.
I also set a 0 gauge pressure in the the outlet... And a backflow turbulent Intensity and length scale same as inlet. I am not sure about this backflow setup but have no problems by now.
Leonardo.flores is offline   Reply With Quote
Old   May 4, 2018, 08:09
ck3
Khaled
Hi Leonardo.
First, I want to thank you for your replay.I need your help for these two questions:
1. What is the best type of mesh to use (C, H or O-grid)?
2. what model of turbulence you advise me to useRegards,
Old   May 4, 2018, 11:13
Leonardo
1. Most papers I read use structured rectangular grid with a O-grid of the cylinder. Check this video tutorial of a mesh made in ICEM CFD Structered Grid on Cylinder in ICEMCFD. I will share you a kinda refined mesh I use with a Y+=1 for a Reynolds= 140 000. https://drive.google.com/file/d/1PJu...ew?usp=sharing
So I think this is the best mesh type. You can control the blockage ratio (diameter/Mesh height), downstream lenght, and many others.
2. I am using K-w SST, since it has k-w and k-epsilon features. Its very common for bluff bodies. But, it might take many computational resources for high Reynolds since you need a y+=1-5. If you dont have a good cpu you can start with k-epsilon y+=30. Check this paper, they perform simulations with 3 kind of k-epsilon models Tutar - Cylinder
After performing your initial simulations with k-epsilon or k-omega SST go for transitional models... and then for LES.
Old   May 4, 2018, 12:55
ck3
Khaled
thank you very much, I will try to follow your advice.
Old   May 4, 2018, 13:20
Leonardo
Np, let me know your results if you can, I am interested on Re=3900. What parameters are you monitoring?
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
2D cylinder Turbulent Flow fredicenci OpenFOAM Running, Solving & CFD 13 December 5, 2017 19:10
Strange flow partern (Reverse Flow) in fluid past circular cylinder problem at exit HectorRedal Main CFD Forum 9 June 9, 2016 19:14
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 18:51
