How To Review Residuals After Closing & Re-Opening Fluent
Like Tree9Likes
  • 1 Post By m_ridzon
  • 8 Post By m_ridzon
Old   April 28, 2018, 09:20
Default How To Review Residuals After Closing & Re-Opening Fluent
Matt Ridzon
m_ridzon is on a distinguished road
I think this is a novice question. Nevertheless, I'm new and don't know the answer. I solved a model in Fluent last week. Today I re-opened the software and would like to review the progression of the residuals through the solution. Is there a way to look at those plots again without re-solving the model?
Note, I'm using v182 ANSYS.
Thanks in advance!
M Ridzon
m_ridzon is offline   Reply With Quote
Old   April 28, 2018, 17:15
nuha
miss chemical is on a distinguished road
I put the steps in the photos
miss chemical is offline   Reply With Quote
Old   April 29, 2018, 09:29
Matt Ridzon
Hmm, okay. Sounds archaic. I guess I assumed the software had more sophistication than that. Nevertheless, I suppose that's what I'll do. Thanks for the tip.
M Ridzon
miss chemical likes this.
Old   August 18, 2018, 09:59
Matt Ridzon
Update for anybody who might benefit from what I just learned...
When you re-open Fluent, you can click Monitors > Residuals in the tree. In the residuals window, you can click Plot to show the residuals from the previous run. It's very simple and I was happy to accidentally stumble onto this.
Small disclaimer though...taking these steps will plot the primary residuals (velocity and continuity). I haven't figured out if or how you can also replot other residuals (e.g., lift or drag) once you re-open a Fluent session.
Papes, jigarfaria, AliHY and 5 others like this.
Old   December 16, 2019, 12:25
bischofp is on a distinguished road
Hey M Rizon
I just closed my residual plot by accident and found your post here. If I do klick on the residuals and plot it does not work for my. Do you know any other variant by now?
Cheers,
Edit: oke after closing fluent and reopening fluent and reading the case and data your variant works. Apparently it does not work if you only close the residual plot and like to reopen it again.
bischofp is offline   Reply With Quote
Old   January 12, 2020, 11:00
UchihaMadara is on a distinguished road
where are these photos?
UchihaMadara is offline   Reply With Quote
Old   June 8, 2021, 02:10
Jigar
jigarfaria is on a distinguished road
It worked for me. Thanks.
jigarfaria is offline   Reply With Quote
Old   August 10, 2021, 08:22
Thumbs up
hadrami_hamdan
hadrami is on a distinguished road
hi
to reopen your previous residual plot
open up your solution> then go to postprocessing tab> then click residuals
sorry i dont know how to post pictures here
anything can pm me hadramihamdan@gmail.com
hadrami is offline   Reply With Quote
Old   April 7, 2022, 08:07
Question Funny thing
Cesare Ghionoiu Martínez
cesaaargm is on a distinguished road
Hi, I think it belongs more or less to this thread.
A funny thing I noticed is that the X-axis (iterations) of my residuals plot is different between:
  • Solution>Monitors>Residual plot and;
  • Simulation reports>View report
I attach a photo of it.
https://imagizer.imageshack.com/img922/2554/ppTVXm.png
The values are the ones of the 5000th iteration but the X-axis gets to the 1000th only, but on the 1000th iteration the residual was much higher than what is shown.
cesaaargm is offline   Reply With Quote
Old   June 25, 2024, 05:29
Default ANSYS Fluent
Deepak Kumar
Deepak_48 is on a distinguished road
Originally Posted by hadrami View Post
hi
After running the setup, exit the window and open solution tab below it and go to Monitor > Residual (double click) > select plot you will see the las iteration you had done in setup, similarly you can see the report file graph.
For more help contact:
akhani.deepak@yahoo.com
Deepak_48 is offline   Reply With Quote
Simple question: Opening Fluent from Workbench vs opening directly? Ericson FLUENT 6 April 19, 2023 12:15
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
error in opening fluent in ansys workbench tmeysam92 ANSYS 3 March 12, 2013 07:10
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
Fluent Parallel/Serial version..jump in residuals Sandeep Abhyankar FLUENT 4 January 10, 2000 10:57
