May 8, 2018, 09:13 |
Friction between object and wall in Fluent
Dear All,
I was trying to simulate the movement of a solid ball-like object sliding on the wall of a pipe. The simulation is made in 2D. I have used 6 DOF to simulate the ball movement as it's being pushed forward by the air flow (about 3.6 m3/s in a 500 mm diameter pipe. The ball is 400 mm in diameter). I would like to know how to add friction contact between the sliding ball and the pipe wall to study the variation of the ball velocity through the pipe as the pipe is 170 m long. Do I need to do something in the meshing step as well to introduce the friction?! Last edited by Hisoka; May 9, 2018 at 12:26. |
contact, friction, sliding |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
error in fireFoam, when running the case wallFireSpread2D | zhoubiao1088 | OpenFOAM Running, Solving & CFD | 9 | February 1, 2018 18:45 |
Paraview Compiling Error (OpenFOAM 2.1.x + openSUSE 12.2) | sfigato | OpenFOAM Installation | 22 | January 31, 2013 10:16 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 06:23 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
