May 8, 2018, 06:00 |
Boundary Conditions for M2129 Duct Flow
Alex
Rep Power: 8 |
Hi, I am relatively inexperienced in Fluent and need help with identifying correct BCs to use at the inlet and outlet, for the given flow properties.
The case is a 3D model of the RAE M2129 S-duct. The conditions are (from AGARD AR-270) : P_t = 101215.771 Pa T_t = 293 K M_flight = 0.210 M_throat = 0.412 Non-dimensional weight flow = .197 in^2 K^0.5 s^-1 M_compressor face = 0.304 Pressure recovery = 0.9897 I am currently modelling just from the bellmouth intake (0.1294m ahead of the throat - assumed straight section purely for boundary layer growth) to the engine face. I have set the fluid to Ideal Gas, as the flow is compressible for M=0.412. I think I want to specify this velocity at the inlet, but cannot use velocity-inlet as that is for incompressible flow models only. I have tried understanding the Fluent guide re. BCs online, and looked around for solutions, but have not found any. Any advice would be welcomed, thanks. Alex |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
