How to use translation and rotation periodic boundary condition in helical pipe? |
May 23, 2018, 15:53 |
teguh hady
Rep Power: 17 |
Dear all
I want to simulate helical pipe, due to computational effort, I only simulate small part by using combination of periodic boundary condition of translation and rotation. I have tried to find any reference about it but I don’t get any article about this problem. Do you have any advice? thank you Teguh
Now Or Never!!! |
May 23, 2018, 18:10 |
Lucky
Rep Power: 65 |
You need to extend your domain so that you can apply the translation only periodic BC.
The formulation is based on Patankar's work, which is derived for the translation only case. The math already looks wonky to me the translation + rotationally periodic configuration. The main issue being how does one even impose the rotation periodic constraint on an x,y,z coordinate system? and then how to handle the pressure gradient? |
June 6, 2018, 22:21 |
teguh hady
Rep Power: 17 |
Dear LuckyTran
Thank you for your suggestion. I am sorry for late reply. Yes, I have tried your suggestion. I lengthen the pipe until one turn. The position of the periodic boundary condition is same only have a pitch distance. It works. Thank you so much best regards
Now Or Never!!! |
August 14, 2019, 05:30 |
Desireddy Shashidhar Reddy
Hi teguhtf,
I am trying to do what you said. The solution doesn't converge. I created a helical pipe with one complete turn. d = 4 mm, p = 6 mm, D = 36 mm. I created the transnational periodic zone. What are your solver settings ? Thank you. |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
[ANSYS Meshing] Solution to periodic boundary problem | SophieLee | ANSYS Meshing & Geometry | 1 | June 28, 2017 01:51 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
Handling boundary condition in Fluent | sak | FLUENT | 6 | March 25, 2013 15:21 |
periodic Boundary Condition for unstructured grid | MLJ | Main CFD Forum | 2 | June 16, 2000 05:57 |
