May 31, 2018, 16:26 |
CFD optimization in ANSYS Fluent
Ebi
Rep Power: 17 |
Dear all,
Hope you are doing well. Would you please guide me how can I solve the following problem via ANSYS Fluent? Thanks in advance. Assume a fixed 2-D shape which consist of walls and edges dedicated to the boundary conditions (bcs) including velocity inlet and pressure outlet. I want to find the optimal layout(configuration) of the bcs i.e. which of them would be velocity inlet and the other as pressure outlet? The number of edges(bcs) and the velocity/pressure values at the boundaries are fixed. Moreover, the criterion for choosing the optimal arrangement is not important. As mentioned, the geometry is fixed and the problem is to find the optimal layout for inlet/outlet boundaries. For example, if there are five edges (~five bcs), which combination is appropriate for the problem: 2 for velocity inlet and 3 for pressure outlet? or 1+4 or 4+1? How can I employ ANSYS FLuent to solve this specific kind of optimization which is not the shape/topology optimization problem? Many thanks |
CFD in Aerospace using ansys fluent | Si Med | FLUENT | 0 | May 19, 2018 13:31 |
Is it possible to render results from ANSYS CFD codes like Fluent or Polyfolw using B | dsaen | ANSYS | 1 | May 1, 2018 03:23 |
concentric tube heat exchanger cfd analysis using ansys fluent | Rohith | FLUENT | 0 | April 9, 2018 09:25 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation | Volker P. | ANSYS Meshing & Geometry | 22 | January 17, 2012 17:27 |
