[Sponsors] | |||||
Nived Sankar
Rep Power: 9 ![]() |
I need to model a bundle of pipes arranged above each other. The diameter of the pipes is 20mm. The distance between the pipes is 40mm. I need to model wall roughness on the outer side of pipes. How to calculate the values of roughness height and roughness constant?
Nived Sankar
Somebody pls help me find the range of values for roughness height.
Baris PULAT
Rep Power: 11 ![]() |
Here are some values for the roughness of pipes with different materials.
http://www.spray.com/calculators/Pre...Calc/rauh.html For the roughness constant fluent manual gives you the information. https://www.sharcnet.ca/Software/Flu...ug/node253.htm If you can do a quick search on this forum and also google, you can find pretty much everything you need. Baris |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wall Roughness - Rough Wall | Rodrigo_Eng_Mect | CFX | 6 | April 13, 2021 09:19 |
| Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
| Defining wall Roughness in laminar flows | SH_P | FLUENT | 1 | April 28, 2012 17:34 |
| Modelling roughness with a laminar flow in Fluent | 1000sh | Main CFD Forum | 0 | April 16, 2010 15:41 |
| Assigning Wall Roughness in STAR-CD | Sachin | Siemens | 1 | March 11, 2008 12:24 |
