Temperature
Like Tree1Likes
  • 1 Post By Noix_V
Old   June 9, 2018, 16:29
Default Temperature
yassin iledaf
Yassinez is on a distinguished road
I have a simple domain 2D; the inlet is pipe (8mm) in a domain of 4m² (pressure outlet), I want the air coming into the domain to have a temperature of 340kelvin, Can someone please tell me how to do that? everythingelse is ambiant.
Yassinez is offline   Reply With Quote
Old   June 9, 2018, 21:27
Noix
Noix_V is on a distinguished road
You mean that the inlet fluid has a set temperature? Just enable the energy equation, then choose the "Thermal" tab on your inlet border condition and set the value you want.
Yassinez likes this.
Noix_V is offline   Reply With Quote
Old   June 10, 2018, 16:16
yassin iledaf
the problem is the domain tepmerature, I want the domain to be at the ambiant temperature so that i can see the domain heating up. boundaries are all pressure outlet
Old   June 10, 2018, 17:08
Cyrus69 is on a distinguished road
hi
as i understand, u have a pipe as an inlet that push the air to ur domain(4m^2)
.is that correct?
if yes there's no temp diffrence.if theres a temp diffrence in ur problem, send a sketch from ur geomtry and conditions.
Cyrus69 is offline   Reply With Quote
Old   June 10, 2018, 17:24
yassin iledaf
Here is a sketch,
Old   June 10, 2018, 19:07
what r ur datas?
1-what's the speed and temp of inlet air?(properties of inlet air)
2-are ur walls inulated or not? if not what's the properties?
Old   June 11, 2018, 10:59
Lucky
This is a transient problem. You want to set the air inlet temperature to be 340K as a boundary condition.
For the ambient air in the domain, you want to set its initial temperature (at say time = 0s) to be 300K. You set this in the initialization.
Old   June 11, 2018, 12:08
yassin iledaf
the velocity in the inlet is 5m/s
temperature is 340k
the boundaries are not WALLS their set to PRESSURE OUTLET
please help.
Old   June 11, 2018, 12:17
RaiderDoctor is on a distinguished road
I think LuckyTran gave you your answer. Initialize the domain as the ambient temperature using Standard Initialization methods. Then model your case as a transient study with the inlet set to what you previously described.
RaiderDoctor is offline   Reply With Quote
Old   June 11, 2018, 12:45
yassin iledaf
I use hybrid initialization
Old   June 11, 2018, 12:53
If you use hybrid initialization, you will not be able to set the domain temperature. It will instead interpolate it from the inlet temperature, which is not what you want. Using Standard Initialization, under the Initial Values, set the temperature to whatever you need it to be set to initially. As you simulate, the change in temperature will be calculated from you inlet.
Shadow Wall and temperature norger FLUENT 10 September 28, 2019 12:43
Static temperature and Total temperature Jong-Yoon FLUENT 0 September 25, 2016 02:42
How to get free stream temperature in boundary condition saharesobh FLUENT 0 October 9, 2012 18:12
difference of temperature HKH FLUENT 0 January 28, 2010 03:45
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 18:31
