parallel calculation with multi-processor unit Ansys Fluent 19? |
June 14, 2018, 20:51 |
Adam
Rep Power: 8 |
Dear Researchgate member,
i try to simulation diesel engine with Ansys fluent 19 i use a laptop with 04 processor, as below details : Welcome to ANSYS Fluent Release 19.1 Copyright 1987-2018 ANSYS, Inc. All Rights Reserved. Unauthorized use, distribution or duplication is prohibited. This product is subject to U.S. laws governing export and re-export. For full Legal Notice, see documentation. Build Time: Apr 9 2018 14:07:31 Build Id: 10123 Host spawning Node 0 on machine "DESKTOP-JPAIALE" (win64). WARNING: No cached password or password provided. use '-pass' or '-cache' to provide password Host 0 -- ip 192.168.1.111 -- ranks 0 - 3 host | 0 ======|====== 0 : SHM Prot - All Intra-node communication is: SHM ------------------------------------------------------------------------------- ID Hostname Core O.S. PID Vendor ------------------------------------------------------------------------------- n3 DESKTOP-JPAIALE 4/4 Windows-x64 6236 Intel(R) Core(TM) i7-6500U n2 DESKTOP-JPAIALE 3/4 Windows-x64 11924 Intel(R) Core(TM) i7-6500U n1 DESKTOP-JPAIALE 2/4 Windows-x64 10636 Intel(R) Core(TM) i7-6500U n0* DESKTOP-JPAIALE 1/4 Windows-x64 8660 Intel(R) Core(TM) i7-6500U host DESKTOP-JPAIALE Windows-x64 7228 Intel(R) Core(TM) i7-6500U MPI Option Selected: ibmmpi Selected system interconnect: default ------------------------------------------------------------------------------- Cleanup script file is F:\DR_GML\2018_CFD_Ansys Fluent\mechanism_load90\22_mai_18 _enhanced_mesh_without_ports\test05_ansys 19\cleanup-fluent-DESKTOP-JPAIALE-7228.bat ** just after hybrid initialization I get the following error : 999999: mpt_accept: error: accept failed: No such file or directory 999999: mpt_accept: error: accept failed: No such file or directory MPI Application rank 0 exited before MPI_Finalize() with status 2 The fl process could not be started. **please help me, how to solve this issue, it is urgent for me , even I can't do a serial calculation , i got the following error : 999999: mpt_accept: error: accept failed: No such file or directory 999999: mpt_accept: error: accept failedMPI Application rank 0 exited before MPI_Finalize() with status 2 The fl process could not be started. Thanks in advance for your help |
June 15, 2018, 04:57 |
Rep Power: 11 |
Hi Adam,
From the transcript that you sent, it looks like your path has a space in it. I advise you to get rid of that space. (*Probably* not an issue here, but it will be if you start using UDFs.) Other thoughts: -- Try "standard" initialization instead. -- Check that you are not missing any input files (flamelet models, inlet profiles, viewfactors, or whatever). -- Go through all the settings and check that there are no blank entries. -- Go through all the monitor definitions and check that they are valid. Maybe, as a paranoid measure, delete all the monitor plots, all the monitor files and all the report definitions (in that order). -- You could try the "Check Case" button. -- If none of this works, try a simpler case (maybe a tutorial), to troubleshoot whether the problem is with that case or the whole installation. Good luck! Ed |
June 15, 2018, 11:24 |
Lucky
Rep Power: 65 |
This is some parallel/mpi error. In fluent 19 there is no longer a serial mode so don't expect it to fix anything. Try using a different mpi, you are using ibm mpi.
June 16, 2018, 20:54 |
Adam
Rep Power: 8 |
Dear Lucky,
i use intel MPI i want just to perform a serial calculation because my laptop is not strong ( I7 6500u with 12 gram) thanks in advance Last edited by Adam_PHD; June 18, 2018 at 13:08. |
Fluent in Ansys Workbench : Change Working Directory | sral | FLUENT | 4 | March 29, 2019 11:29 |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 01:49 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 01:17 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 13:07 |
Parallel Processing on ANSYS FLUENT 12 | srr | FLUENT | 2 | April 16, 2011 15:16 |
