Fluent Eror
I took an error but I couldn't solve it. Can you help me?
"error: file "D:\akis 2_files\dp0\FFF\Fluent\airfoil-2 dat.gz Error object: %f" What need I do? *I use ANSYS 18 and 18.1 |
This error message has already been discussed at: https://www.cfd-online.com/Forums/fl...sh-fluent.html
Typically, the folders and names of files should not have spaces. Use "_" or "-" to indicate spaces. |
But it is so strange, because I don't have something like that, Also, I am doing introduction of fluent. I did everything same. I made mesh with automatic.
I took new error;
Error: Workbench Error: Could not handle command Error Object: %f Error: File "C:\Users\Hp\AppData\Local\Temp\WB_LAPTOP-05BTF57J_HP_10012_2\unsaved_project_files\dp0\FFF\ Fluent\nozzle.dat" Error Object: %f |
First of all, remove the spaces in the names of your files and folders. You have one space in the "akis 2_files" folder and one space in the filename "airfoil-2 dat.gz" which is also not saved as a .dat.gz file (missing the dot).
I have another question, When I want to Fİle ->Write->Case... I couldn't find it. When I went to write plot, It doesn't has write button. I have write button in "import". I have ANSYS 18 and 18.1 |
I start to hate from fluent, Can I find some analysis from a website? I want to look an analysis which is complated. Then I will see What is the mine fault.
Read the users guide and tutorials (available in the help section) for detailed step by step instructions for setting up and running simulations in Fluent. There are also third party tutorials available online, such as from Cornell University.
