Importing .stl to fluent
Old   July 9, 2018, 16:22
Question Importing .stl to fluent
Mahdi Hasan
mahdihasan is on a distinguished road
Dear All,
I have a geometry file which is in stl format. I edited the geometry using solidworks to close the open ends adn saved it as .igs format. The problem is when I imported the solid geometry in fluent, I get warning of exceeding the academic version limit. I think that the problem is due to the no. of faces. The limit is 300 faces and I have way more than that.I am unable to merge those faces. I can't also use ICEM CFD as the ansys student doesn't have it. Can anyone please help to find a solution of this problem? I can share the geometry file if anyone wants to take a look.
Thank You.
mahdihasan is offline   Reply With Quote
Exporting Fluent adjoint boundary mesh as .stl or parasolid. _11_ FLUENT 1 April 1, 2020 02:22
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM guxin7005 FLUENT 2 June 27, 2016 22:41
[Commercial meshers] Separating regions Problem after importing from Fluent Mesher peterhess OpenFOAM Meshing & Mesh Conversion 1 March 1, 2016 09:45
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Importing Gridgen into Fluent travis.moulding ANSYS 4 April 5, 2010 10:38
