July 13, 2018, 11:55 |
Converging-diverging nozzle
Rep Power: 7 |
So I'm new to Fluent and I'm trying to do a simulation of a Converging-diverging nozzle. For starts, I'm considering inviscid flow. I'm supposed to obtain a supersonic flow downstream the throat followed by a normal shock. However, I can't seem to achive these two phenomena. I think I'm messing something up setting the BC.
Here's what's given: * Mach number inlet: Ma= 0.239543 * Stactic pressure inlet: p_s_inlet=1 bar=10^5 Pa * Stactic pressure outlet: p_s_exit =0.83049*p_s_inlet * Total temperature inlet: 300 K I calculated the total inlet pressure using the Mach number and pressure relation. Set the Operating Pressure to 0, so I can work with absolute pressures. Here's what my inlet and outlet BC look like: Pressure Inlet: https://imgur.com/a/KzFpodi Pressure Outlet: https://imgur.com/a/F9JPnLE I'm working with air as an ideal gas. I set the inlet BC to Pressure Inlet because of compressibility. So, any ideas why I can't get to the results I need? Do you guys see anything wrong with the BC? I fully appreciate and look forward to your replies. Thanks in advance. Note: if imgur hosting is not appropriate I can change it. Sorry for anything. UPDATE: here are the contours of Mach numbers for the simulation with the BC above. It's converged in 2015 iterations. https://imgur.com/a/6kQxMOf |
July 13, 2018, 18:12 |
Lucky
Rep Power: 65 |
Is the throat area small enough to choke the flow?
July 14, 2018, 05:08 |
Behrooz Jamshidi
This is not a CFD problem. First of all your flow needs to be choked. Choked flow is independent of geometry. For air as working fluid, your discharge pressure must be less than 0.53*Pinlet. While you set discharge pressure as 0.83* Pinlet, it is obvious that you can not get choked flow and subsequently shock.
Fluid Dissociation in Converging Diverging Nozzle | Yuqi | FLUENT | 2 | May 29, 2018 11:53 |
How to determine the distance between points on Converging diverging nozzle geometry | Sorwar22 | FLUENT | 0 | December 4, 2017 20:07 |
Help needed with my Converging diverging nozzle | Sorwar22 | FLUENT | 6 | November 8, 2017 17:24 |
Converging Diverging Nozzle in OpenFOAM | danishdude | OpenFOAM Running, Solving & CFD | 1 | September 15, 2012 00:12 |
help - Running Converging Diverging Nozzle with a shock wave | Daco | FLUENT | 0 | September 3, 2012 08:23 |
