Mixing axisymmetry and convective boundary condition
Old   July 20, 2018, 06:40
Default Mixing axisymmetry and convective boundary condition
MV78 is on a distinguished road
I am working on a shell-and-tube heat exchanger. The model is 2D axisymmetric. I'd like to model the heat transfer from the inner tube with a convective boundary condition.
Without a convective boundary condition, the axisymmetry axis corresponds to the bottom side of my rectangular domain. However, when I represent my fluid with a convective boundary condition the domain is reduced. The bottom side corresponds now to the convective boundary condition and I can no longer define an axisymmetry axis as it is out of the boundary limits. Creating a separate line disconnected from the mesh isn't possible.
I could use a planar symmetry to get around this problem but it will introduce errors. Does anyone know how I could proceed ?
Thank you in advance,
MV78
MV78 is offline   Reply With Quote
Old   July 20, 2018, 10:43
Lucky
In 2D the axis for the axisymmetric condition is always the x=0 line. You only need the axis BC when you have a boundary on the axis (e.g. in a pipe). For an annulus I think you don't need to do anything.
Old   July 20, 2018, 11:19
Of course. Let's say that the axis is the x=0 line. I want to define a convective boundary condition for the line x=0.01 and there is no domain between the convective BC and the axis. However, my problem is that the axis has to be a boundary condition of a domain to exist.
I may be unable to see the solution as I am working with Hypermesh for the mesh.
Old   July 20, 2018, 21:07
Lucky
I'm not sure why you actually need to specify an axis because the imported mesh is a 2D rectangle or something. It sounds like you have a hypermesh problem and not a Fluent problem.
A possible workaround though is to generate your 2D rectangle using an axis at x=0. Import this mesh into Fluent. Then translate it upwards along y to x=0.01 m.
Old   July 21, 2018, 07:57
The rectangular geometry represents the 2D axisymmetric model of the shell-and-tube heat exchanger. I don't have a problem to generate the axis along the x=0 line, I can create a perfect axisymmetric model. The issue arises when I want to simplify my model with a convective BC at x=0.01 instead of the hot transfer fluid. I can't specify an axis at x=0 as it isn't a domain boundary anymore, the one from the former hot transfer fluid domain.
Old   July 21, 2018, 17:39
Lucky
You don't need to specify an axis at x=0, the axis is always at x=0. You only use the axis BC when you actually have a boundary at x=0, because otherwise it would be missing a BC. If you do not have a boundary at x=0, then you don't need to do anything more. You only need to specify that it is a 2D axisymmetric type simulation in the setup.
