How to solve the problem with simulating a pipe with pressure inlet and outflow BC fo |
August 12, 2018, 08:14 |
mostafa
Rep Power: 9 |
when we don't know what kind of property is in the outlet, we use "outflow" BC. now I just have inlet pressure and I want to simply see the pressure drop along the pipe.
I set the pressure in the Inlet, but when I want to set outflow boundary condition for outlet, the fluent give warning: "Both outflow and pressure boundaries are present in the domain. This is an incompatibility and the solution cannot proceed until this is fixed." How can I solve this problem? |
August 12, 2018, 08:31 |
subhankar das
Rep Power: 7 |
I also have this problem in case of open channel flow
August 13, 2018, 04:06 |
Bijan
Rep Power: 11 |
In pipe flow you have to either choose velocity inlet and outflow in order to find pressure drop along the pipe or pressure inlet and pressure outlet to find velocity profiles. There is no way for fluent to solve the problem with pressure inlet and outflow because as you said the outlet conditions are unknown.
August 13, 2018, 07:41 |
#4 | |
mostafa
Rep Power: 9 |
August 13, 2018, 11:29 |
Lucky
Rep Power: 65 |
The problem is simply underdefined when you have a pressure inlet and outflow BC pair because you know nothing about the flowrate. There are infinite possibilities of the velocity (zero being one of them) that satisfies your pressure inlet constraint and outflow constraint. Remember the outflow BC simply means whatever arrives at the outlet flows out. You need something to fix the flowrate/velocity.
You probably want to use a pressure outlet w/ targeted mass flow rate option. This let's you fix the inlet pressure and allows you to set a flowrate and get the pressure drop. |
boundary condition, piping |
Display Modes | |
Total pressure and mass flow boundary condition at inlet | bscphil | OpenFOAM Pre-Processing | 3 | July 9, 2017 14:39 |
Outflow boundary condition in cartesian grid SIMPLE velocity-pressure coupling | ghobold | Main CFD Forum | 9 | September 19, 2015 02:50 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 11:14 |
outflow BC for closed pipe (no inlet) | tej | FLUENT | 1 | May 14, 2004 10:25 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
