[Error] Fluent Not Responding on Workbench Environment
I've been working in Fluent for the past months and there is one recurrent error that happens when simulating through workbench on Linux (Ansys 17.0 on CentOS). Depending on the number of iterations, from 15 to 25K depending on the mesh, the program ceases to respond without returning any error or message. The only thing that pops up is the system message. Some few hypothesis came in mind, one that fluent requires an special permission for writing files and the second one that it just takes some time to unload the memory, since it still uses a certain percentage of RAM available. I can't open Fluent and simulate from it, due to the lack of GPU from the server we use at the facility. Did anyone come across this error or has a suggestion of what to do? Many thanks, Luiz |
There are no special permissions in unix/linux, only permissions.
Why don't you try running Fluent without the gui to debug? You can launch Fluent in nogui mode... |
I didn't open in the no gui mode (trying this rn), because I was using Solution Monitoring to oversee the simulation. Even after the program crashes, I can see the transcript from fluent and it doesn't show any error, only that one of the processes were killed.
The reason I killed the process is that the CPU usage went to zero and there was no updates on the monitors anymore. |
Issue
dmesg |
I am not using any UDF, and the parallel calculus uses 52/64 cores in a single machine. I will take a look at this issue, but it doesn't seem to be the case since RAM usage doesn't go above 19/128 Gb. I am not very familiar with this term, but this error can be that the process needs more memory than what CentOS allows right? If it is the case how can I improve this limit? Increasing its swap?
Will if you have 128 Gb of RAM then you might not need swap space at all. You can check various settings by
ulimit -a You really should launch fluent in console mode (i.e., without GUI) so that you could capture the error message. Once you have solved the problem you can run in graphical mode as you like. |
I managed to simulate it further than before without any error without GUI. Although, I encountered a difficulty when it comes to export the data within a time range, ex: data in 1 s, 2 s, 3s and the final solution.
I wrote a journal script, although I am not certain what expression to use to export these results to CFD-Post. Its idea is quite simple, just do an permanent solution and use it as an initialization to a transient one. Code:
rc Trans-sst-init.cas |
You can set it from GUI under [file]->export->during calculation.
Does it keep this configuration once I run no GUI?
Also, for when it runs in transient mode in GUI I can save my time series in one file using autosave(timesteps), the export process goes through workbench. Is it possible to use this same autosave and export a time series with [file]->export->cfd post compatible in a same file using a journal? If it doesn't should I write an UDF for such? Thanks in advance. |
