August 20, 2018, 06:45 |
Error: cell is missing face
Yahia
Rep Power: 7 |
Hello everybody,
I'm meshing a half model of a serpentine (offset) duct in ICEM CFD. Initial geometry had been created in SolidWorks and then imported to ICEM CFD. The created hexahedral mesh is of a good quality and neither Error nor Possible Problem was detected during check/fix. The only problem that I face is while I import the mesh into fluent. An error of "cell is missing face" is prompted as in the attached figure. Importing any mesh rather than hexa mesh (Blocking) is going smoothly and no error prompted. Any suggestion will be highly appreciated. Please don't hesitate to ask for any additional illustrating figures. Best regards Yahia Attachment 65164 Attachment 65165 Attachment 65166 |
August 25, 2018, 06:26 |
#3 | |
Yahia
Rep Power: 7 |
Half Model.pdf HM error.pdf Dear Blackmask, For more clarification, I'm gonna state all the steps followed during meshing as follow: 1. The geometry was imported to ICEM CFD in .igs extension. 2. Parts were created as Inlet, Outlet, Wall and Symmetry. 3. Material point was created as FLUID. 4. Topology was built using filtering angles that less than 30 degree. 5. Block was initialized and split. 6. Since the duct is offset, "extrusion along a curve" method was utilized in order to block the whole duct. 7. Vertices, edges, faces were associated to points, curves and surfaces respectively. 8. Mesh size was set on the surfaces and pre-mesh was converted to unstructured mesh. 9. Output to fluent and BC's were specified. 10. Mesh file was written to Fluent. However while importing to fluent still error of cell is missing face prompted. Best regards |
August 27, 2018, 01:32 |
Thank you for your detailed explanation. I see no problem if everything is done as you said. However, please check which surface is located near (-50.88, 165.6, -71.2) and make sure that this surface is associated with block faces. Also, make sure that ICEMCFD does not issue any warning when you export unstructured FLUENT mesh.
August 29, 2018, 04:36 |
#5 | |
Yahia
Rep Power: 7 |
I just want to inform you that importing the mesh is done . I just tried to associate each and every single face to the geometry surfaces after O-grid generation. It seems to me that generating the O-grid will result in non-associating faces that have to be associated after. I really appreciate your cooperation. Thanks indeed. Best regards. |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[ANSYS Meshing] Difficulty in mesh upload to ansys fluent | Ayo_gboyega | ANSYS Meshing & Geometry | 1 | June 17, 2018 03:02 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
gmsh2ToFoam | sarajags_89 | OpenFOAM | 0 | November 24, 2009 22:50 |
