How to assign material properties when they are varying with temperature
I am trying to simulate the laser melting of a magnesium alloy. The properties of the alloy vary with temperature. https://i.imgur.com/71qxe8x.jpg How do I enter these values in the FLUENT solver when I create a new material? Thanks. |
Plot them in excel and put the trend line over it to get the coefficients, after that you should be able to do it this way:
http://jullio.pe.kr/fluent6.1/help/html/ug/node282.htm |
https://i.imgur.com/0XhKy0Q.jpg X-axis indicates temperature, while Y-axis indicates density. What should I do next? |
Using a curve-fit function, get the polynomial coefficients and insert them into material properties in FLUENT.
Regards. |
