Set heat flux BC at wall for changing temperature
Old   October 4, 2018, 08:19
Default Set heat flux BC at wall for changing temperature
Stroopwafelandcoffee is on a distinguished road
I'm trying to simulate the heat transfer between air-flow at constant temperature and a battery cell which changes its temperature over time. I know the heat generation rate and initial temperature of the battery cell. I also know the flow velocity and the temperature of the air stream surrounding it, but I'm not quite sure how I should define the boundary condition.
The heat flux depends on both temperatures, but the temperature of the battery cell is not constant (it heats up as we start drawing current), so the temperature and heat flux changes over time. Is there a way to define a time dependent battery cell temperature?
Or am I missing something?
Stroopwafelandcoffee is offline   Reply With Quote
Old   October 4, 2018, 11:53
Lucky Tran
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
I can't really follow what you are trying to do so let's go through the steps like we are learning it for the first time. Let's go over the knowns and constraints.
What is the domain? Battery only, flow only, or battery and flow?
What are the physics?
What are the known BC's so far? Then we can identify the needed BC's.
Old   October 10, 2018, 09:33
Sorry for the extremely late response. But for now we solved it by assuming constant temperature. If we need changing temperature in the future we'll cross that bridge then. For now we're taking it one step at a time.
convection, fluent, temperature, thermal
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 11:52
bulk mean temperature 2D flow constant heat flux at one wall shan2baba FLUENT 0 January 9, 2015 03:44
Temperature and heat flux wall boundary condition L. Hamid Main CFD Forum 3 February 22, 2014 21:10
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 21:41
