B.C. to simulate open space
Old   October 16, 2018, 03:58
Default B.C. to simulate open space
Mattia
Comi is on a distinguished road
Hi, can any of you give me an advice regarding how to simulate open space with Fluent?
In my model I need to extract the surface temperatures of an heat exchanger in open space, the device is positioned at a certain distance from the floor and a wall. In order to reduce the number of elements I used simmetry on one side.
I placed the heat exchanger into a limited volume of air. If I assign the wall boundary condition to the walls that surround the air volume it would be like simulate the heat exchanger into a box, so is there a way to assign an open space-like B.C. to these walls?
Thanks very much
Comi is offline   Reply With Quote
Old   October 16, 2018, 11:51
RaiderDoctor is on a distinguished road
Can you post a pic of your fluid domain with arrows pointing to your boundaries, and what conditions you assign them?
RaiderDoctor is offline   Reply With Quote
Old   October 16, 2018, 12:17
Lucky
A pressure inlet or a pressure outlet should work.
Old   October 17, 2018, 04:59
Mattia
Thanks, I will try that
Old   October 17, 2018, 07:20
Mattia
I have another question: in order to use pressure inlet or pressure outlet I should set the Gauge Pressure to zero right? The operating pressure is still at default value
Old   October 17, 2018, 10:33
Lucky
Right... If you keep the default operating pressure (which is ~1 atm) and set a zero gauge pressure, then your boundary condition is ~1atm of absolute static pressure.
Old   November 5, 2018, 07:17
Mattia
Regarding your request here is a pick of the geometry, due to some circumstances I can't show you the details.
I have a radiator that hang on a wall, the radiator has n eletric resistance inside and i want to know what will be the surface temperature at steady state.
That is why I needed the open space like BC. Unfortunately using the pressure inlet or pressure outlet I can't reach a satisfying solution, probably i'm missing something again.
I'm using pressure based solver, the resistance is a parallelepiped that is not included into the domain, I just gave the W/m2 distribution at the surfaces that represent the resistence. The resistence is in contact both with the raditator and the air.
Old   November 7, 2018, 06:09
Mattia
Another question: even though I impose a certain energy flux on the surfaces of the resistance the fluid fluxes are all wrong. Instead of having hot air going versus the top of the volume , air just enter from the top side of the pressure inlet and exit from the bottom. I tried to cheat by puttting a pressure outlet on the top of the volume but the direction of the flux doesn't change.
Any suggestion?
I'm using k-epsilon turbulence model, s2s, pressure based solver
Thank you
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
openfoam 1.6 on debian etch romant OpenFOAM Installation 9 May 6, 2010 03:26
