October 19, 2018, 13:16 |
Velocity representation at exit
Hamed Abdul Majeed
Rep Power: 13 |
I have three ways to represent velocity (left to right in image below):
1. Velocity contours nodal values at outlet. 2. Velocity vectors at outlet. 3. Velocity contours (nodal values are unchecked) at outlet. Q1. Which is the right way to represent the velocity? Q2. Why is velocity for 1st case (velocity contours nodal values) zero? |
October 19, 2018, 15:06 |
Lucky
Rep Power: 65 |
Node values are values at the vertexes. If you don't check node values, then you are looking at face values.
By any chance do you only have 1 cell across your annulus? Then all your vertices are on walls and it makes sense your node values are 0 everywhere because of no-slip. |
atmBoundaryLayerInletVelocity - Velocity Profile not continuous through domain | sdfij6354 | OpenFOAM Running, Solving & CFD | 3 | July 26, 2017 16:16 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
[OpenFOAM] Annotate velocity of specific cell or point | jwstolk | ParaView | 4 | August 5, 2016 05:50 |
Having trouble adapting serial UDF to work in parallel | muyuntao | Fluent UDF and Scheme Programming | 1 | November 10, 2015 13:42 |
Exit Velocity of a Mach 2.2 Jet | oe_jet | Main CFD Forum | 0 | June 24, 2010 15:36 |
