Inlet and outlet conditions for actuator disc sim
Old   November 7, 2018, 10:10
Default Inlet and outlet conditions for actuator disc sim
Stroopwafelandcoffee is on a distinguished road
So I'm currently trying to model an actuator disc simulation of a propeller. I've got my fan domain with pressure difference set up and I've got my surrounding nearfield and farfield set up as well. I was just wondering what inlet and outlet conditions to use for the far upstream inlet and far downstream outlet. Would a traditional velocity-inlet/pressure-outlet configuration be best? What velocity value should be used? If not, could a pressure-inlet/pressure-outlet be a possibility?
Thanks for the help
Stroopwafelandcoffee is offline   Reply With Quote
Old   November 7, 2018, 11:03
Lucky Tran
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
The outlet should be a pressure outlet with ambient pressure as the BC.
The inlet should also be a pressure inlet, with ambient pressure as the BC. Probably you are not aware that at pressure inlets you are specifying the stagnation pressure (not the static pressure).
Your fan does all the work to push the flow through the domain, assuming you have set it up properly.
Old   November 7, 2018, 11:40
Thanks. I already thought a pressure-inlet made more sense, but had to be sure.
actuator disc, boundary conditions, fluent, inlet, outlet
interFoam (HELYX-OS) pressure boundary conditions SFr OpenFOAM Running, Solving & CFD 8 June 23, 2016 17:36
how to extract outlet conditions & put it as inlet for same saksham Main CFD Forum 2 November 26, 2014 09:08
Boundary Conditions: Pressure Inlet, Velocity Outlet BigPapi34 OpenFOAM Running, Solving & CFD 4 August 2, 2014 12:39
recirc tank, inlet outlet conditions david CFX 1 May 22, 2007 04:23
Inlet and Outlet Boundary conditions for LES Jan Ramboer Main CFD Forum 12 August 6, 1999 23:00
