Vortex Tube flow simulation in Fluent
Old   November 9, 2018, 15:02
Default Vortex Tube flow simulation in Fluent
CFDguy11 is on a distinguished road
Hey everyone!
New to this forum but it has been an invaluable resource so I'm really glad that it exists!
I am a university student trying to model the flow in a Ranque-Hilsch vortex tube and have been able to successfully obtain the vortex flow behaviour (see attached picture).
However, I am not able to see a proper temperature/heat exchange between outer and inner vortices take place, as a result I'm not able to get a temperature difference at the Hot and Cold end. A contour plot of the tube at its midpoint doesn't really show any heat transfer taking place...
Does this have to do with setting a Backflow temperature for Hot and Cold outlets? I am using the K-e model with Viscous heating, compressibility effects and pressure gradient effects enabled.
Looking forward to your input, I would be happy to provide any additional information. Thank you so much!
CFDguy11 is offline   Reply With Quote
Old   November 12, 2018, 14:30
Lucky Tran
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
Note that you probably do not need compressibility effects or pressure gradient effects because these options are for the turbulence model. The vortex tube can work even in a totally laminar flow, it really has nothing to do with turbulence.
Make sure you are using a compressible equation of state (i.e. ideal gas) and not constant density of temperature dependent density.
Are you using the pressure based solver? The kinetic energy term is generally disabled in the energy equation when you use the pressure based solver. This means you do not see the adiabatic compression/expansion effects due to conversion between bulk kinetic energy of the flow and flow temperature. To enable it, you need to type something like:
/define/models/energy
then follow the prompts to activate the terms
Old   March 11, 2019, 18:18
Thank you for your reply LuckyTran,
I am using the Pressure Based solver with the Energy equation enabled. In fluent, under 'Model' on the left-hand side, clicked on 'Energy' and checked the box.
On second thought, I wonder whether I am running enough iterations. I set max iterations to 20000, and K and epsilon terms are squiggling and hovering between 1E-3 and 1E-4. The energy term is between 1E-5 and 1E-6. Continuity term at 1E-2, all squiggly. Would you recommend letting it solve for longer? say, 50000 iterations?
Thank you so much for your help!
Old   March 11, 2019, 22:26
As you can see from the attached image, this is the temperature contour I am getting. I set the total temperature in the 'THERMAL' tab of the inlet to 300K (assuming this was the inlet temperature of the air). The pressure-outlets (hot end and cold end) are set to 0 gauge pressure, and the 'THERMAL' tab has a backflow temperature setting of 300K for each of the outlets. I am unable to see a proper temperature gradient on both hot and cold ends even after 20000 iterations.
Fluent phase change in a horizontal tube eliastorca FLUENT 2 September 8, 2018 10:03
Shock Tube Simulation in Ansys Fluent MHS78 CFD Freelancers 0 July 28, 2016 07:12
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
simulating vortex tube in fluent and its boundary condition mojtaba7192 FLUENT 0 August 11, 2013 03:51
reversed flow in unsteady simulation with dynamic mesh (fluent 12.1) zhaoyu_001 FLUENT 0 April 7, 2010 00:24
