Identify residuals
Old   November 14, 2018, 10:34
Default Identify residuals
acalado's Avatar
André
acalado is on a distinguished road
Hi guys,
does anyone know if any of the newer versions of Fluent allow you to plot / locate residuals like x-momentum or energy, and not just mast balance? It is quite frustrating since that would help pinpoint where issues might be, whether they are related to physics or mesh.
Thanks in advance!
Sapere aude!
acalado is offline   Reply With Quote
Old   November 14, 2018, 10:41
Lucky
You have to enable an option to save the cell residuals by typing in the following command into the TUI:
solve/set/expert n y n n
(the defaults are n n n n)
the y enables the option in "Save cell residual for post-processing?"
Then make sure you do some new iterations to generate and create these fields (and possibly save the new cas & dat file if you want to use a post-processor). Then there will be variables under the residuals category that you can visualize within Fluent. They will also now be saved into the .dat file and you can also see them in a post-processor like tecplot or CFD-Post.
Old   November 14, 2018, 12:00
acalado's Avatar
André
Thanks a lot!
Sapere aude!
Why did the residuals increase after flattened out as I continued the iteration? pchoopanya ANSYS 1 May 20, 2018 03:31
plot residuals pigna OpenFOAM Running, Solving & CFD 2 December 19, 2014 02:32
motorBike Residuals for SST k-omega... and mine JR22 OpenFOAM Running, Solving & CFD 6 August 1, 2013 09:08
judging convergence through residuals MachZero Main CFD Forum 7 December 25, 2012 12:18
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 05:45
