November 17, 2018, 07:24 |
Choosing laminar or turbulent model
Nived Sankar
Rep Power: 8 |
Iam doing a CFD simulation on horizontal cylinders placed vertically above one another. The top cylinder is rotating while the bottom cylinder is stationary. Iam facing difficulty in whether to choose laminar or turbulent model. Iam attaching my geometry here.
2 cylinders one above another. Both are heated cylinders 800W/m2K Diameter 0.0254m Distance between the cylinders is varied as 2D, 4D, 6D Top cylinder is rotated at 200 rpm, 400 rpm, and 600rpm. Please somebody help.... |
November 18, 2018, 02:50 |
Nived Sankar
Rep Power: 8 |
Pls somebody help....
November 19, 2018, 08:23 |
Rep Power: 18 |
Google Reynolds.
November 20, 2018, 10:57 |
André
Rep Power: 10 |
I would try seeing if with the RPM you are proposing, if there is any characteristic Reynolds based on this that would case turbulent flow around the cylinder.
Otherwise, just try running laminar and see if you have any issues with convergence. If you do you can try changing models.
Sapere aude! |
November 20, 2018, 14:16 |
Natural cconvection in cylinder 2D
Nived Sankar
Rep Power: 8 |
Iam trying to simulate natural convection in a cylinder. Iam considering rectangular domain around cylinder. To study the influence of domain, i tried increasing the domain size...but the temperature on cylinder increases continuously as the domain size increases.
Cylinder dia 25.4cm Heat flux 800W/m2K Why does this happen?? What to do? |
November 22, 2018, 02:10 |
Jiri
Rep Power: 13 |
Do you consider radiation? What type of boundary condition is the rectangle domain? Wall, far-field, inlet and outlet?
November 26, 2018, 07:52 |
dear sir, the flow regime of natural convection is determined by the Grasholf number, so compute the Gr number first based on the heat flux of the cylinder.
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Turbulent Model versus laminar in openFoam | cleoo | OpenFOAM Programming & Development | 1 | September 8, 2016 14:06 |
choosing turbulence model for gas phase while laminar model for solid phase | Haiqin | STAR-CCM+ | 3 | July 12, 2016 04:45 |
Confused with Laminar Finite-rate model and EDC model | tjushang | FLUENT | 2 | April 25, 2015 17:04 |
Half laminar and turbulent model trying to solve | Andrew Clarke | FLUENT | 5 | May 19, 2008 13:40 |
