Increase in pressure drop when refine the mesh |
December 5, 2018, 06:12 |
Rep Power: 7 |
Hello everyone,
I am Simulating a heattransfer problem with Ansys Fluent as seen on the attached picture. Setup.jpg I'm Using K-Omega-SST Turbulencemodel with "Coupled" Pressure-Velocity Coupling and the Pseudo-Transient formulation. Deactivating the Pseudo-Transient Solver leeds to the same results with slower convergence. When performing a mesh independence study, i experienced a weird behaviour. As i increased my cell count, the pressure drop increased. The picture below shows the pressure drop over a mesh parameter. Doubling the mesh parameter will leed to 8 times more cells. MeshRefinement.png As we can see the pressure drop is increasing, but i never reach mesh independence. Refining the mesh even more is an option i want to avoid, since i allready got 6 million Elements in a 2x5x15 mm domain. The Mesh is as good as it can get. Max. y+ Values are at 0,8 for most of the meshes. The y+ of the finest meshes are even lower. I experienced the same behaviour with larger Setups, which contain more of the periodic geometries and using fixed velocity inlet and pressure outlet. My question is, is there something wrong with my setup? Can i use symmetry boundary conditions (since the geometry is symmetrical I assume I can)? |
December 5, 2018, 08:22 |
André
Rep Power: 10 |
Are you using symmetry to essentially "double" your domain?
Which wall treatment functions are you using? I'm assuming near wall if your y+ is near 1. And your results don't look too different. Between first and last mesh there is about 1% relative difference, which I would think is a good enough solution. Cheers
Sapere aude! |
December 5, 2018, 09:03 |
Lucky
Rep Power: 65 |
Looks good. Forget the phrase mesh independence, it's mesh sensitivity.
However, I am skeptical your results for any given mesh are that accurate. For example you're saying that, for a fixed mesh, as you iterate your pressure drop stays exactly 622.5 +/- 0 and doesn't oscillate at all? Put numerical error bars on this plot. I wouldn't be surprised to see 622.5 +/- 5. |
December 5, 2018, 12:13 |
#4 | ||
Rep Power: 7 |
When I understand it correctly, the SST model is switching automatically between Wall Functions and near wall treatment. Since i'm at y+<1 i assume, that im using near wall treatment. Am I wrong here? Do i need to use the "Low-Re Correction" to enable near wall treatment? Quote:
Sorry i didn't mention my convergence criterias. I defined my own convergence criteria by monitoring the "Periodic Pressure Gradient" and the "Bulk Temperature Ratio". My simulation is converged when both variables differ less than 1e-6 in the last 50 iterations. So the results aren't differ in 6th significant digits. I am very sure that my Results are not oscillating anymore. BTW all of my residuals are way below 1e-10. |
December 5, 2018, 14:13 |
#5 | |
Lucky
Rep Power: 65 |
But regardless, I think you've got some nice results. |
independence, periodic, pressure, symmetry |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Total pressure drop & static pressure drop | Aarthar | Main CFD Forum | 3 | April 11, 2018 03:32 |
Repeated elements in a system – pressure drop | llidito | OpenFOAM | 0 | April 25, 2013 14:47 |
