ANSYS 19.2: Journal File has no effect on the calculation
Old   December 19, 2018, 10:26
Default ANSYS 19.2: Journal File has no effect on the calculation
sufjanst is on a distinguished road
Hi everyone,
I have a very simple case and I want to analyize the impact of the turbulent Schmidt number on the solution.
I want to try turbulent Schmidt numbers from 0.1 to 1 using a journal file.
I have an already initialized case and I tried
rcd <start case>
(rpsetvar' species/sct 0.1)
sol/it 1000
wcd <case with sct 0.1>
(rpsetvar' species/sct 0.2)
sol/it 1000
wcd <case with sct 0.2>
I checked the files and the turbulent Schmidt Number changed in the Viscous settings (k-w-SST) during the run. The problem is that the changing of the Schmidt number via TUI has no impact on the calculation.
Whenever I change the Schmidt Number manually in the GUI it does affect the calculation.
I think this is pretty strange. Does someone have a solution?
sufjanst is offline   Reply With Quote
Old   December 19, 2018, 10:56
Lucky Tran
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
Nope
Sounds like a bug that you should report to customer support.
Old   December 19, 2018, 23:01
Alexander
AlexanderZ will become famous soon enough
check spelling
was
should be
(rpsetvar 'species/sct 0.1)
however, this may not be the reason
best regards
AlexanderZ is offline   Reply With Quote
Old   December 20, 2018, 03:27
Originally Posted by AlexanderZ View Post
check spelling
was
should be
best regards
Thanks, you are right. But this is not the reason and does not solve the problem. However, it is possible to write a journal-file which changes the Schmidt-number in the GUI. So it works now. Thanks anyway!
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 101 February 2, 2017 23:36
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
