flow with free surface, dynamic mesh, vof, 6dof |
December 23, 2018, 12:37 |
Kevin Sandoval
Rep Power: 7 |
Dear, I have to do a 2d simulation, flowing around a ship, to analyze how it behaves with a certain slip, analyzing the balance it experiences, I have seen that the VOF model is used to separate the two phases involved and the Dynamic meshing with 6dof properties, also conjugating two meshes, utlilizing the "overset" between these two meshes, the bottom and the mesh that moves in a passive way with respect to the floating cuepo, I have had difficulty making this meshing, someone could Tell me how to do the meshing with the overset between these two meshes, would it be better to write an UDF for the movement of my mesh? Some recommendations that can give me to face the problem, I will be attentive to your comments and thank you very much! flow with free surface, dynamic mesh, vof, 6dof
dynamic mesh, free surface, overset mesh, vof |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
UDF Defining VOF Free Surface at Outlet | Alex | Fluent UDF and Scheme Programming | 13 | August 8, 2012 16:50 |
