December 28, 2018, 06:45 |
Turn inlet and outlet to boundary condition
Maria
Rep Power: 7 |
I am using a reactor which was initially simulated, in transient state, with two inlets (at the bottom) and and two outlets (at the top). Now that the dynamic behaviour of the fluids inside the reactor is stabilized, I want to transform the inlets (inlet 1 and 2) and outlets (outlet 1 and 2) into a boundary condition, i.e., what goes out through inlet 1 will reenter in inlet 1 and the same for inlet and outlet 2. I transformed the inlet 1 and outlet 1 into walls (81 and 113) and tryied to use the manual boundary condition comands: /mesh/modify-zones> make-periodic Periodic zone [()] 81 Shadow zone [()] 113 Rotational periodic? (if no, translational) [yes] yes Create periodic zones? [yes] yes But I get this error: Error: Failed to make zones periodic. Error Object: #f Am I doing something wrong or it is not possible to do this ? Thank you in advance, Joana Matos. |
December 30, 2018, 15:12 |
Lucky
Rep Power: 65 |
Why did you answer yes to rotational? That's your problem.
Note that for the periodic pair creation to be successful the grid needs to be conformal at the boundaries. Otherwise you need to create a periodic interface. |
December 30, 2018, 15:20 |
Maria
Rep Power: 7 |
Thank you. Actually I tried both rotational and translational. I changed the mesh so it is conformal and the perioidc boundaries, with translational, are done. I'm having convergence problems now: "floating point". I tried several methods, but could not solve the problem...
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
How to unserstand Correct boundary condition at outlet for incompressible flow? | aja1345 | FLUENT | 3 | July 16, 2018 12:12 |
map outlet boundary profile as an inlet condition using UDF | Daniel_Khazaei | Fluent UDF and Scheme Programming | 2 | June 20, 2016 11:53 |
boundary condition for coupled inlet and outlet | xxxx | OpenFOAM Pre-Processing | 2 | August 13, 2013 15:51 |
inlet and outlet boundary condition of pump | Thammasak | CFX | 0 | February 9, 2004 13:02 |
