January 24, 2019, 02:35 |
Problem in reading journal file
saeed
Hello
I am using ANSYS 19.1 workbench. I have written an script in ansys 19.1 that is related to Fluent. It opens Fluent and reads Fluent Journal file. The problem is during reading mesh file, it does not wait for the mesh file to be fully loaded so it reads the next line that is related to the energy model, so since the mesh is not yet fully loaded, we encounter an error. anyone can help? Thanks script: system61 = GetSystem(Name="FLU 61") setupComponent61 = system61.GetComponent(Name="Setup") setupComponent61.Reset() setup61 = system61.GetContainer(ComponentName="Setup") fluentLauncherSettings61 = setup61.GetFluentLauncherSettings() fluentLauncherSettings61.SetEntityProperties(Prope rties=Set(DisplayText="Fluent Launcher Settings", Dimension="ThreeD", Precision="Double", EnvPath={}, RunParallel=True, NumberOfProcessors=2)) setup61.Edit() setup61.SendCommand(Command="(cx-gui-do cx-activate-item "MenuBar*ReadSubMenu*Journal...")(cx-gui-do cx-set-file-dialog-entries "Select File" '( "FinalJournal")' "All Files (*)")") setup61.SendCommand(Command='(cx-gui-do cx-activate-item "MenuBar*FileMenu*Close Fluent")') Last edited by srf020; January 24, 2019 at 06:20. |
January 24, 2019, 06:24 |
saeed
I found that journal code can not import mesh . when i type:
> (cx-gui-do cx-activate-item "MenuBar*ImportSubMenu*Mesh...") > (cx-gui-do cx-set-file-dialog-entries "Select File" '( "mesh dir\mesh.msh") "Mesh Files (*.msh* *.MSH* )") TUI return : Resetting session...Resetting session...Done and does no action. |
Display Modes | |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 09:06 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 19:13 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 11:59 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 18:18 |
